Setting RUN DAY LIGHTS "ANGELS ONLY"
andavaka
Hi Guys,
Re: 2006 320i Run Day Lights
When activated both the xenon & ring (angle) lights come on, does anyone know how to set it so that only the ring lights come on!
Hellas
You can wire the rings on a separate switch to work independently from the car's lights. But Motorplan might object...
andavaka
The rings come on alone when the parklights are switched on!!!
But when you have the switch is on "AUTOLIGHTS" and have the RUN DAY LIGHTS on, both the rings and xenons are on!
What i would to have is ONLY the rings on when RUN DAY LIGHTS are on and have the Xenon OFF
