Caddy101 said:
Prini said:
The E90, does not have a set service interval. They service period adjusts to your driving style. If you drive hard your service intervals will become shorter.
I understand that. But 7000km?! Seriously?! I used to service my E46 every 25 000 km and my driving style hasn't changed at all
I spend most of my time in traffic, now and again I get to put my foot down, even then I don't get to 180km/h.
Ok I'll try and explain a bit better.
The E90 does not have everything replaced/serviced when you have the car serviced.
In the E46, depending on which Inspection is due, most items are serviced.
Now on the E90 - your car could have had an oil service done at 98 000kms. The service however that is due now, could be a number of other things like, spark plugs, front brakes, rear brakes, filters, general checkup, emissions test, etc etc etc.
The best is to scroll through Service Menu on the OBD to establish exactly what 'service' the car is referring to.
Concentrate on what is important: driving.
Condition Based Service (CBS).
The intelligent maintenance system CBS permanently monitors oil levels and the degree of wear and tear on individual components. It also checks the time/mileage recommendations for fixed services. It analyses this data and tells you when a service is next due.
Data can be checked at a glance on your Info Display, which automatically gives you four weeks' notice. The iDrive Control Display gives you an exact information on which component needs a check. So you can plan your service appointments well in advance and avoid any unnecessary maintenance work.
Together with BMW TeleServices, the data collected by CBS is automatically transferred to your BMW Service Centre so that they can contact you to arrange an appointment.
CBS Display- Instrument Cluster
The CBS display always comprises the following two separate displays:
• A colored symbol in the upper display
•Orange for normal
•Yellow for service due
•Red for service overdue
• Information on remaining distance and/or due date in the lower display.
https://wiki.bentleypublishers.com/display/tech/Service+indicator+info+and+resetting
