Shiny
Hi Guys,
I just wanted to share a post received by the technical Manager at Cedar Isle Auto. My E85 Z4M recently went for an Inspection 2 service and I queried why valve adjustments were not done, amongst other things.
I was wondering if anyone has had these adjusted and if it is indeed of any importance to get this done.
...We have investigated the service requirements for your car. In South Africa we used to check valve clearances. Due to the fact that they almost never needed adjustment, this item was removed by BMW S.A from the service sheet in early 2005.
With regards to the mobility cartridge, This must be a country specific item. It has never been on our service sheet to replace cartridge. Up to 2005 we used to have to check if the cartridge had been used and report back to the customer if it needed replacement.
With regards to the brake fluid. We change it when 2 years has passed since last flushing.The brake fluid was replaced on your vehicle in 2011 , so it will be replaced at the next service as the 2 years would have lapsed.
In 2006 BMW went away from the service sheet (like the America one you have) and went onto key reader printouts....
