Hi All, a few of the S55's are doing some high mileages now and I have not heard of any 1st hand horror stories. From some basic research it seems to very sporadic and affects stock and modded vehicles. It seems less likely to go as opposed to rod bearing failure on the S65 or S54, but can also cause catastrophic damage.
The pro's and con's of getting it done or not getting it done, is the easy part (basically do you want to Risk it).
If you mod the vehicle, off course the more strain and more likely it is to fail, but my question, has anyone spun a Crank hub, or heard of a spun Crank hub in S.A?
Also this doesn't seem like a wear item, like rod bearings but an item that could be prone to failure due to a flaw in design. If it was a major item prone to fail, would BMW have considered a recall?
