Road test
Raybimmer
CAR magazine Jan 2000 test at coast : 0-100 5.58 s , 0-120 7.51 s , 1km 24.7 s at 219.3 km/h
speeds at 7500 rpm : 65 , 110 , 166 , 222 , 275 . 5 speed box
Topcar Dec 99 test at reef : 0-100 6.23 s , 0-120 8.76 s 1 km 26.2 s at 203.7 km/h
Having hassle with photoshop otherwise would post test copies .
cheers
Clownshoe
cheers
Hmmm, those will be the s50 engine. Downrated for SA I believe:(
Although on the same engine there is is a 25sec difference. I suppose with the wizardry on the s54 the difference should be less... and then the differnce between 6.23 and 5.23 (s50 vs s54 Schnitzer) is not just a second... the power needed is exponential. That is a significant amount of differnce!!!
Whacko
mrv said:
thanks for the info Ray. What a big difference the car makes at the coast...
With a decat and K&N filter I use a microchip unit I built that starts sensing at wheel movement I got 5.5 secs two up. I weigh 116 kg and my son is 100kg. Me alone best time I got was 5.3 secs. I need to calibrate the microchip again as that sounds a bit optimistic. I have an improvised encoder on the rear shaft, and calibrated it on a measured 100m.
Was thinking of building a marketable solution, as GPS does not automate for this type of application.
Sadly the car is going for a rust removal on the right door, it's a small spot but proof of the previous owner's neglect.
Clownshoe
cheers
Very interesting in those magazine articles Raybimmer, hopefully you sort out photoshop:slap: or you can e-mail them to me at stevejr2005 (at) yahoo (dot) com
