Rep Button Missing - WHY?
3seriesman
Hi All, I wanna give rep points to someone that has been rather helpful. But to my disappointment that button is missing. Does anyone have idea why? Attached is a snapshot of his post.:smashScreen:
Yuben
Senior Moderator
Try clicking on the reputation number fir the specific forum member and then go "RATE USER"
Let us know if it works.
Do other Tapatalk users have the same problem?
3seriesman
Yes, tried it Yuben, Forum on the web doesn't have it as well as Tapatalk. Might be a glitch in the system. The techno guys might have to look at this.
3seriesman
Not sure what the minimum post count is for this, cos I am on 32 posts so far
Yuben
Senior Moderator
Try logging on using Chrome or another browser instead of Tapatalk and advise if you still have a problem
ChefDJ
There's no minimum post count requirement.
Working fine on my side. Clear your cache and advise.
Coisman
Administrator
OK...
I logged in as you, (as Admin I can) to check that the Rep button was gone.
I also then logged into a few new users, and in all of them the Rep button is missing :thinking:
...then I logged into a new member that had just over 50 posts, 53 to be exact, and guess what... The Rep button was now there :Idea:
So I think for some reason it might be a setting where you can only give Rep points after you have 50 posts.
I remember a while back, there was a small conflict on the forum, and some guys registered new profiles, only to give out negative rep points to some guys, and boost others with positive rep points, so maybe this stems from that. :dunno:
ChefDJ
Coisman@TheFanatics said:
OK...
Now this would make sense :thinking:
I didn't even realise it.
3seriesman
Ok, thanks guys gonna boost my posting up and let's see if it appears, thanks.
Coisman
Administrator
Just do not spam post ok :thumb:
3seriesman
Ok guys reached 50 posts a few days ago and "yes" the rep button does appear now.
