remove E87 kidney grill?
KarshS
Guys is there an easier way to remove the kidney grills?
Bimmerfest guide is abit tricky with those special tools
Any1 tried removing it already?
3V0M-WP
BMW Car Club Member
Its very easy.
Above the grilles there's about 4 black screws that mount the bumper to the black trimming where the bonnet locks into.
Unscrew those 4 screws, then gently pull the bumper away a little bit so that you can squeeze your hand down to the back of the grilles. While looking thru the grilles from the front, find the clips then unclip them. Push from behind.
Simple as that.
msm
You can use this specialised tool:
images
... oh wait, maybe you still want it in one piece :rollsmile:
KarshS
Carbon130i said:
Its very easy.
Simple as that.
Thanks bro....Will try when i get home....
images
HAHAHAHA HHmmmmm it has never worked in the past:fencelook:
KarshS
aZZ_kIkR said:
yep, exactly the same manner is taking out the E46 and the E90 grilles.
Just that you have to take off or loosen the bumper. Cos with the e87 its in the front bumper and not on the bonnet
Nastaliq
Be mindful that the screws are not normal philips screwheads. You will need a hex set, i think its a T-20 if I am not mistaken
AshG108
yep, you jsut have to loosen the top 4 screws in order to get behind the grills. dude, you know where Jerry stays, i am on the same road, if you ever around, stop by and i can glady assist you if you have not come right already.:thumbs:
KarshS
Thanks bro....I managed to remove it. Maybe you can help me open up the headlight with a heat gun? lol....:argh:
