Hey guys
So I'm in the process of installing lighting in my home theatre room. I have an electrician coming in 2 weeks time to do the installation. The setup will be as follows:
- There will be 6 x 7W dimable LED downlights along the sides of the room
- 2 x 7W dimable LED downlights in a display cabinet on either side of the projector screen
- 24 x 1.5W dimable LED starlights randomly placed in the ceiling.
- 1 x existing non dimable light fixture in the center of the room which I'm keeping as is.
All 4 points above will be running off their own dimmer switches (3 dimmer switches and 1 regular light switch). Everything is 220v with the exception of the starlights which will be run off an extra low voltage transformer.
What I would like to do is have all the lighting in the room controlled by remote. I have a Logitech Harmony One remote which controls everything in the room at the moment and it can be programmed to control just about any IR device so it would be cool to have the lights programmed on it as well.
Anyone with experience on the above have any advice/pointers on what is needed and the best way to set it up?
