Reflections Detailing - OPC Headlight Restore
lambchop
My Mate Danny contacted me in connection with his headlights and wanted to know if i could being them back to life. I thought id take this on as a bit of a challenge as Ive never done a headlight restore.
I must say this was a bit of a ball ache to say the least and very time consuming to ensure the finish was correctly done.
The headlights were treated with 1000 - 1500 -2500 -3000 and machine polished for clarity
Before.
After
Before
After
i also did an engine bay clean as it was a bit grubby and needed a wash
The engine was dressed with Auto Finesse Dressle
Revive in action
Afters
WyKiD
Great result!
I know restorations like this is common practice, tons of online info. There is also mention of UV protection being removed by this process which leads to the return of the dullness and in some cases it happens at an accellarated rate.
Is this fact?
My E39's lights would benefit from a restore but just been apprehensive...
lambchop
WyKiD said:
Great result!
Is this fact?
Well let me ask you this. Your headlights are +- 10 years old full of sand blasting and exposed to UV rays on a daily basis? If "Yes" to any of those questions then basically your headlights are already exposed and the UV protection has been compromised
To be honest you have nothing to lose and would give it a go if I was you. But be warned its not as easy as it looks. Its a very tricky but its not impossible
Good luck
MariusH
What if you put some of that clear protective wrapping on top after restoring it to protect it? Think that will work?
KSINGH
I used glassy lite kit. Comes with new glass paste.
Where did you find 3000 grit? The kit only had a small piece.
lambchop
Got it from one of my detailing connections
Its a meguiars pad. But they expensive
Was that the final product on the right ?
KSINGH
Yes. Did head light too.
Before
After
