P
Psymon69
ok so ive done prettymuch everything but this car still has this stuttering/missing thing!!! :argh::argh::argh::argh::argh:
high gear low rpm if i put foot it stutters
also 1st and second at about 4K and 5K RPM its has this weird missing like a superbike limiting. 3rd gear is better but sometimes it does same thing.
when i just quickly touch accelerator revs go down. also when i pull away revs will usually first go down before it goes up
when cold it idles horrible (not at all) and when hot is slightly surges but not much (sometimes not at all) but this i suspect is the ICV
right what ive tried:
swop coil
new leads
swopped distributor cap
filters are all new
sparkplugs are all prettymuch new
swopped out ECU
new AFM
injector cleaner was put in before my head went and it helped a bit but will put in more when i get a chance to go to midas
tried testing fuel pressure but that just resulted in me with petrol in my eye and on my hair.:bangdesk:
what can this be?
does anyone maybe have a fuel pump to swop out and see if this makes it better? or maybe a proper gauge?
can it be injectors?
im at thr point of taking it to a mechanic and spending too much money on this already
--E30 325i--
swop coil
new leads
filters are all new
swopped out ECU
new AFM
what can this be?
--E30 325i--
