Rare find: SOLEX 40PHH Carbs
R
Rolf
I just found these on Ebay
Suitable for BMW 2002ti restauration
Auction ends in 5 days (26.02.2012)
Coisman
Administrator
:pimp:
I wonder if someone on this forum is actually busy with a project like this?? :thinking:
If not, and they own one, or know someone that owns one, it might be a good idea to buy a spare pair... :dunno:
CLASSICMAN
I've got a set tucked away in a box that I have no plans to use. They need a rebuild, but the kits are available. I'd be willing to let them go for a good ti project.
Carbon
I am doing a 2002ti restoration at the moment, still some way from mechanicals, doing the bodywork now. But I might be interested. The rebuild kits for these are quite scarce and though and as these do not have main shaft bearings it is very expensive to restore if the main shaft is worn.
In what condition is your carbs Classicman?
Regards
Jacques
These carbs came off a 2000ti, not a 2002ti. You can see it from the plenums.
Just for intrest sake.
Regards
Jacques
CLASSICMAN
@Cyclone - Not sure of the condition, came with a car and a lot of spares I bought some time ago. They look complete though. The carb kits were off the market for quite a while and I see they have become available again. Check on eBay in Germany (.de)
I will see if I can take a few photos of the carbs tonight and post them for you.
Raybimmer
" Hallo Oom , eks van Benoni , pas die karbs op n shitty golof , ekke het die hed gegasflow en n 333 kem ingesit ? ":roflol::roflol::roflol:
Carbon
:flyfun: Jy sal verbaas wees hoeveel mense dink ek moet my 2002s "tjoen" en drop. Ai, die kinners van vandag is ook mar clueless.:flyfun:
I saw the kits, thank you. My biggest concern however is the main shaft, if it is worn, the accelerator pump and throttle butterfly do not work linearly anymore and makes it impossible to set up and jet properly. The car will run, just not well, esp. at lower RPM acceleration. Its also an expensive fix unfortunately.
Regards
Jacques
