Quality Check at BMW dealer
streetglow
Good morning all
I am curious know what does the quality check at a bmw dealer consist of?
I also have the following queries, I hope that one of you can point me in the right direction. 
1. Does the dealer check if the rims are damaged (buckled), if so are they responsible to fix it before finalising the quality check and releasing the vehicle to the customer?
2. If the pins on the shock mountings are removed is that concern?
3. My vehicle has been pulling to the left and I was told that’s about normal and that cannot be fixed.:fencelook:
4. I notice the vehicle is sluggish at low rpm, no warning lights are on thou that would suggest it could not be the vvt.
5. The ride quality is very hard and uncomfortable.
6. Economy – 6.1/100 and 9.2/100 local, I suspect that’s about the average?
E90 – 2010 - 320i (m) 49000km
akash
If you are buying the car from BMW they should have everything wrong with the car sorted out for you, DO NOT take delivery until they fix whatever they pic up.
If pins that are suppose to be there are not there then you should have it investigated.
Have the alignment looked at, but the E90's do tend to pull to the left.
Its a 320i so dont expect anything high performance. But have a diagnostic done just in case
If you bought a sport pack the ride is going to be hard and uncomfortable on uneven roads
