Howzit all,
been reading the heated debate about Twinz JB3 and George's Tune in the other thread, thought i would throw a spanner in the works here with a different products results -- the Procede which i installed and played around with over the weekend after BMW FINALLY finished replacing half my car in the last two weeks!
Initially the gains were small and as expected since i have a stock hardware setup running on Sasol 95 Octane fuel - just the Vishnu ECU that all. Then the more runs i did on the dyno the more and more power and torque the engine made thanks to the autotune feature the Procede has.
Baseline run done on my Hyperpower dyno - uncorrected power on the wheels (uncorrected is TRUE power with no sea level correction formula's, its what power was made there and then in those conditions)
Baseline power - 175KW and 330NM at the wheels done on Friday night with 26 deg celcius Air temps and 24% humidity (Totally stock 2008 335i)
Run1 with Map1 (13.5psi 0.92bar setting) increased power nicely
Run2 with Map1 - more increase (dyno graph to follow)
Run3 with Map1 - more increase (dyno graph to follow)
Run4 with Map1 - even more -- (dyno graph to follow)
The reason for the increase is the autotune feature, you simply set your boost ceiling and program the ECU how aggresive you want the map along with ALOT of other tuneable settings, and it does the rest.
Finally after many runs i made 206KW and 447NM at the wheels UNCORRECTED on Sasol 95octane Pump Fuel. I called it a night a went out onto the road -- what a difference!
Saturday around 13H30 i decided to take a run on my dyno again with 35 deg Celcius air temps and 44% humidity - and made 182KW and 378NM due to the heat!
After a datalog with the Procede - I found that the boost ceiling was only reaching 10PSI 0.79bar ... I went into the user adjustable settings and saw that the boost ceiling was in fact set to 13.5PSI 0.92BAR but the ECU would not allow the boost to achieve that due to the air temps being to high. I overlayed the boost and AFR curves aswell as Ignition Correction curves over RPM and its clear that the ignition and boost is being modified as the RPM increases. The autotune feature certainly works extremely well to protect your engine.
I then went to a friends shop to visit and landed up doing more work on the car, and started by doing a baseline run on his Dastek Dyno and achieved a similar 207KW power reading at the wheels on his dyno using the same MAP settings as i used when i achieved the 206KW run on my Hyperpower dyno. We then started tinkering ...
I added some fuel additives to the tank and did a few more runs, and eventually landed up with 227KW and 470NM at the wheels and peaked there.
Then we did a small mod to the fuel system and made a few more changes to the settings in the ECU and finally managed to get a 252KW and 505NM at the wheels. These tests were done on a Dastek Dyno - graph attached below.
After each achievement 206KW, 227KW and 252KW i had a benchmark car which we raced each time to check the results - and no doubt the results are REAL - The benchmark car was a Volvo T5 with all the mods which include intercooler, downpipe, full exhaust, boost increased to 1.0bar with tune etc.
First run out 206KW setting - neck and neck off the line, and i managed to pull a + - 3 car length on him around 200km/h
Second run 227KW setting - off the line i managed to pull away a nice lead and kept pulling up till high speeds where there was a + - 7 car lead.
Last run late afternoon, 252KW setting from the word go, i pulled and pulled and at a scary 272km/h clock speed i had approximately 20 cars lead. The poor traction light was bliking all the way through 2nd gear.
Sunday morning i am going to run the car again on my hyperpower dyno to compare runs and i will report the results back again.
