Power steering noise
Chandreshd
Hi, I need some help. I got an E46 330i and as my car idles, the power steering makes a noise. I noticed the bottle is a bit messy though. When I turn the steering wheel, it whines. Please help or can I get this fixed or get a second hand pump
frikkieh
Ensure the PS fluid is topped up. Mine also leaks out the top. It ran dry once and made the whine noise that you describe.
Chandreshd
Thanks, will try that, how far to the top must it be? And what make and type of fluid must I put in coz I heard there is red and green
frikkieh
I used some ATF fluid from Midas. It is red stuff and worked for me.
Mine has a little dipstick and it should just touch the top mark.
Check out this thread:
http://www.bimmerfest.com/forums/showthread.php?t=214439
Philip Foglar
Check this thread, very easy to do! http://www.bimmerfest.com/forums/showthread.php?t=214439 - Edit, same as above! :)
And other E46 info: http://www.bimmerfest.com/wiki/index.php/BMW_E46
