pls comment on service for 320d
CliftonH
Hi. I need to service my E90 320d 2005 model. I need to know where to get the parts. What parts to get. What oild to buy. It has 140 000km on it. I have a guy that will service it cheap for me. I just need the parts. I also have a problem cause I tried calling around and apparently the diesel filter is not listed that can't be true. I live in lenz jhb south but prepared to drive out to buy the parts to a max abt 60km radius. Please reccomend where to go and what parts to get and a number if possible and what oil pls. I leave for kzn on saturday and need to change oil before I go as its over due already
D
Dippies
I would recommend you make use of Liqui Moly Top Tec 4100 5W40.
The diesel spec is usually next to the API spec. So for petrol cars the latest API spec is SM, for diesel it is CF.
Your car requires an API rated oil with a CF spec. This is vital!
Furthermore, your vehicle has 30 000km drain intervals which means you need a LL04 BMW approval on your oil. LL04 means a 2004 Longlife Approval.
So you need a CF specced oil, with a LL04 BMW Approval.
It also only costs R380.00 for 5Lt and your car needs 5.5L
http://www.liqui-moly.de/liquimoly/produktdb.nsf/id/en_3700.html?OpenDocument&land=DE
:thumbs:
CliftonH
:thumbs:
Thanks. Any idea where I can get the oil.
You mention that my car has a 30 000km drain does that mean I only have to change the oil every 30 000km. Will the oil filter. Diesel filter and air filter also only need changing at 30 000km. Or does that last longer or shorter.
Thanks. :ty:
I sell liquimoly :) free shipping on 10l but its going to be a push to get it to you before saturday :(
just change the oil when the car tells you to...
the filters are normally not badly priced at the dealer :rollsmile:
flyhid
HI there
There is an oke that work from Lenasia south shop is called 7000rpm .He is not very expensive and he uses BMW parts.
His RMI approved and can stamp your book.
Also just check with the dealers i saw that they not too expensive for oil changed on the 320d.
his number 0835158263
Fahid
CliftonH
I got a guy who is charging me R250 labour. His highly recommed as well. I saw the service book now and it seems air filter and diesel has never been changed. I'm trying to save money to spend more in kzn on holiday. I also seen motolek in lenz sells the liqui molly will go try tomorrow. How bad will it be if I just change oil and oil filter and change the air filter and diesel filter end of march. Fuel consumption is still good and car drives fine currently.
Hi. How much is it for the 10l. I will make a plan for this service to get it. You don't sell other service parts as well.
D
Dippies
I did forward you a PM that will provide all the info you require :thumbs:
my price on 5l is R 420 (Dippies quoted last years price there may be a few shops with old stock at that price to if you find buy it up :) )
dont use 20w-50 its too thick and not recommended for your car...
CliftonH
Hi morano. Where u based. This mech is gonna use some ttt oil and says its R480 for the oil. If u not far maybe I can rush there to buy the oil. Also can u give me ur number so if I can't make it this time I can call u for next time.
ClassicB
Oil and oil filter is not expensive at the dealer. The airfilter costs between R500-R600 if i remember correctly, and i hear it is a pain to change out, that is why dealers dont do it regularly.
balsak
Oil service is R1632 at the dealers that includes the micro filter oil oil filter and a other bunch of scrap i have no idea of got this qoute at Autobahn bmw in Kempton
I was out of office in the afternoon... Im in KZN so not really much help with such short time... I would just buy from BMW seeing as you so short on time... hope you came right :)
