StealthM
Hi Everyone,
I could really use some help or guidance with the issues I am facing now and would greatly appreciate your input. I need a second/third opinion as I really don't want to get screwed over and still sit my the problems I currently have.
I own a 2007 BMW E81 130i M Sport and since my purchase in April this year, I have had to spend a lot of time and money getting issues resolved. I had a major service done as the DISA Flap connector pin broke off and got stuck between the head and the valve causing the valve to stay open and the rocker arm disconnected. I also had a massive oil leak originating from a broken oil filter housing bolt and the valve cover gasket.
Engine flushed, replaced oil with Shell 5W40, Bosh Spark Plugs, Valve cover gasket, intake gaskets, Vanos seals, oil filter gaskets, air filter, cabin filter and brake pads were all done. Full inspection of engine after the DISA flap incident and I was extremely lucky that nothing got hurt. Next up is al 4 discs and front shocks that need replacement. I did Not replace the DISA Flaps, instead had it removed since they are ridiculously expensive and were told the don't HAVE to be there, and the car would run normally without them. I just read that the bottom end torque will not be the same but I don't know how much of a performance impact this really had as the car still feels the same without them. Oh, and this is advice I got from the workshop guru at our BMW branch...
However, since I bought my car, I suspected that it was running rich and the fuel consumption wasn't normal. I took the car to BMW to have a diagnostic scan done by them and they cleared the fault codes as well as the steering lock fault. But they apparently can't supply me with a list of the current fault codes that remain since my PDC Module and 2 PDC sensors are dead. They said I should first buy the module and 2 sensors, have it installed, then they can code it and they Insisted that the latest version of my car's software be loaded. Only then can they scan for any faults, especially on the DME. This never made sense to me so I had the car scanned again by my mechanic and the only fault codes active is something with the CAS module. No DME faults. I could be wrong by my thinking is that if my car gives me 4.2 to 4.7 km per litre in town shifting between 3500 to 4000 rmp and 5.7 km per litre driving like a granny and 3.3 km per litre if I am really stepping on it... then something clearly isn't right. I have spoken to a few people and this consumption is not normal. I am thinking that it could be the MAF, injectors, coil, vacuum leak or O2 sensors, but some or other sensor should "complain'' to the DME logging fault or something since I believe the ECU must be adding fueling or something in order to compensate for something else that is wrong.
How is it that no codes exist and the fuel consumption is that bad. I took the car for a highway drive doing only 120km/h with cruse control and never went over that speed. Did 140km then filled up again and got an average of 9.2km per litre... is this really normal? shouldn't it be more like 11 or close to 12 km per litre at that speed on the highway with 24 degrees temperature?
I spoke to another guy that said the complete diagnostics can only be done if the PDC unit is working because currently with it not working, the other modules will not reflect correctly and could be the cause of the fault codes not being logged. So i guess i would have to find a second hand PDC Unit and 2 sensors, then have the PDC Module coded and then only can we do a proper scan to see exactly what is wrong.
Basically, all I want to know is what parts to replace to fix my car. besides the horrific fuel consumption is the loss in power. the car seems to idle normally, but does have a blurb now and then but quickly comes back to about 600 rpm. I can't afford just to replace parts and having to find out it didn't fix my problem.
can you please advise if my way of thinking is right or if I am being fed b@llsh!t here. This is my first BMW so I am new to all of this and coding and modules stuff....... All I know is I love my 6 cylinder and really want to see her healthy and performing like she was designed to!
I would be grateful for any advice.
Thanks for reading.
Oh, and I thought that after the DISA Flaps removal that they might give error codes ...? Not sure as I struggle to find info on the internet about people that removed them. Just about how much damage it could do to the cylinder head, pistons and valves. But if it is supposed to give fault codes, no one is able to pick them up with a scan. Someone even mentioned to me that he wonders if there isn't some aftermarket software loaded on the car or loaded to deliberately not give a check engine light on the dash and thus the reason why BMW insists on new software version. Why not keep the existing software?
Oh and after giving BMW the go ahead to load the new software, I waited 5 weeks for my dealership to call me to bring the car. They said they waited for an open line to Germany as it is reprogrammed by them and not the local dealer.... Understood but how the hell can it take 5 weeks to get a connection to Germany? Or am I missing something?
Thanks for reading.
