Riaan335 said:My biggest concern is filtration effeciency.
Some of these filters only keep out bigger birds and stones.
Small birds and smaller stones might get through
moranor@axis said:well if i rub my finger on the clean side of the air box no more dust than with a paper filter as far as i can tell :rollsmile:
Riaan335 said:I live in the NW, lots of dust and small birds.
KSINGH said:Riaan335 said:My biggest concern is filtration effeciency.
Stop talking kak man!![]()
Riaan335 said:KSINGH said:Riaan335 said:My biggest concern is filtration effeciency.
Jirre, don't you have a sense of humour? It was a bit tongue in cheek, and overly exaggerated. But still valid.
What micron are the OEM filter rated at, and also the K&N and other after market filters?
If an OEM is 3 micron, and an aftermarket 5 micron, then surely there would slip more dust particles through. And if you neglect the maintenance on your aftermarket filter, or clean it with an aircompressor, you're gonna have trouble.
BTW, the micron figures mentioned above is not fact, only numbers to state my point. I will try to get correct figures...
Sankekur said:On a oiled filter it depends on how you oil it....
