Overdue introduction
incredimills
Hi all,
I have been a long time reader and think its time for an introduction.
Current car: 2016 F22 220i Msport Mineral Grey Metallic
The car is standard except for VPS front guard done at VPS randburg
A bit of history Ex: 2004 E46 320d Stahlblau Metallic
incredimills
So to update this tread.
The one thing I wish was speced on the car that was missing is cruise control, having read a number of threads on the retrofit I decided to take the plunge. I picked up a used MSport steering wheel with the correct MFSW buttons installed then this weekend.
On the coding side I didn't feel comfortable with Esys so I searched for a way to code in cruise control using Bimmercode. After hours I came across the following FDL codes, coded them with Bimmercode expert and all works 100% :smilebounce: .
If anyone would like an MSport wheel without the buttons, let me know and ill post some pics of it and you can make an offer. Its has the trim as well as the paddle shifter, however the left paddle is missing.
Code:
FEM_01 > 3140 PfLinSteeringWheel > LIN_VARIANTE_MFL = DCC_Sports_SLD
FEM_01 > 3140 PfLinSteeringWheel > MFL_VERBAULT = aktiv
HU_NBT > 3001 EXBOX > DCC = aktiv
KOMBI > 3003 FZG_Ausstattung > LDM_VERBAUT = DCC (OEM ldm_off)
ICMQL > 3000 Daten > C_Fahrfunktion = DCC (OEM keine_funktion)
ICMQL > 3000 Daten > C_MF_Lenkrad = verbaut
