Out of Mplan E92 325i
Hi Guys,
As of today, My 325i is out of motorplan.
I've done some research and I should be fine as these engines are quite solid, Plus no turbo means no turbo issues :roflol:
Now I just need to find a decent set of 313's...
johndoe said:
dont the 325i's also have valve stem seal issues after 100K km's?
Yes, possibly but that's not a super expensive problem. And my car is 15000 kms under 100k anyway...
As a note. Is there anything preventative to do to avoid this issue ?
vjx
tappet noise from my 08 325i. Sort out before motoplan expired. Camshaft got changed.
1L oil cosumed every 10k km.
After motoplan around 130k km now, cam position solenoid and O2 sensor after cat shows fault. Storng fuel smell when cold start.
Also be aware of electrical water pump.
