Oil light
4u2nv
Hello there pps...
Can someone explain to me the following?
My m3 flashes 9 times exactly everytime when I start,it is nerve wrecking to see an oil light flash, I checked the oil level it is slightly more full then the usual as I just had an oil change?
Help please?
jeff_denning
Did you change the oil at the dealership? If you did, I think they where supposed to reset the light. Maybe that's the problem?
4u2nv
Hi, This was not at a dealer, but a BMW techie, I reset the light myself tho. this is the oil light at the bottom of the dash not the top oil light.
jeff_denning
Maybe this will help?
http://www.bimmerfest.com/forums/showpost.php?p=3119723&postcount=6
while i was at the garage i asked them why my oil light flashed 9 times exactly everytime i turned the ignition on??
in there response they checked oil pressure and oil level and checked the oil was all ok and said to me it was just a faulty sensor!! so i have now orderd a sensor from them to cure let alone another problem with the car!!
hope this helps to the oil warning light problem!!
4u2nv
Any prices on those sensors, can one fit them oneself or is it a big job? if the sensor is only the issue?
