[email protected]
I recently acquired an E46 330i 2004 with 167 000.km on the clock. I am slowly fixing it to get it top notch. Issues 1 -The car has 2 pumps on the window water bottle and from the manual the other pump is for the headlights washer. Does this work and if so how do you activate it? 2 - The car needs 0.5l of oil every 5 000.km , is this normal. 3 - Also at speeds of 140 and above there is some air noise on the drivers side like between the widscreen and the door. Although there are no signs of rubber damage and the window does close tightly, is this norm? Can anyone fix this for me. 4- The car uses a cd for its navigation system and its out of date were can I get an updated cd for southern Africa and at what cost? I know most of these issue can be addressed at BMW , for me its a no go area unless ubsolutely necessary. Many thanks
