Noizy Clutch
E36Fanatic
Hi guys, I drive an E36 323i and it had a whining noise from the clutch ever since I got the car. Problem is that the noise has increased over the last few drives.
The clutch isn't slipping and the gear change is still quite smooth, and the whining noise is only there when the clutch is released. As soon as I press the clutch the noise stops.
I also feel a slight vibration when resting my foot on the clutch.
Can anyone advise me on what the problem could be?
Any help would be highly appreciated.
Thanks guys.
danieljames
So harsh....boet I suggest u go intro urself. These guys are on a mission this week lol. Banning and stalking people
UpNcOmiNg!
Events Organiser
Could be thrust bearing.
I would try introducing yourself to the forum before using us, then check if the problem still exists.....
Further to that, best bet is to pull the gearbox and replace the thrust bearing.
Dhp507
Yes happened to me ....................until it goes poof and u stuck at a traffic light..............the release bearing is really cheap....under a hundred bucks.
Coast me 25 times that for not changing it ..........:thumbs:
E36Fanatic
How big of a job is it to replace it? And where can I get a quality part for a decent price?
Dhp507
Went into the shop had to have new clutch kit an.Flywheel installed. I suggest u check this out a.s.a.p. That was about 8 years ago. Now it cost a bit more if you dont have it looked at.
You can check with most spares shops. Goldwagen , Midas etc......one days job to fit if your clutch is gone if not two hours work to fit the bearing. Though most people will just refresh everything while doing it
E36Fanatic
I will definitely look into it a.s.a.p. I think I will also go the route of getting a complete clutch kit and refresh everything.
Thanks a lot for the help..
