NF Diesel BOOST
D
Dippies
This has been in debate for ever and i am still siting with questions pertaining to this issue.
I am hoping there is someone with the Technical Knowledge that will be able to help answer this question Please.
What is the risk to Diesel Engines when you over Dilute on NF Diesel Boost. Example What would happen to your engine if you have a half or less tank Diesel and you add 3 or more bottles of NF diesel boost and you over dilute the recommended product specifications.
What is the risk to your engine.
I hope you understand my Question.
mr mmm
Banned
i do stock a booster just for diesels so send me a pm
Executer
Inactive
HOW GREAT YOU ARE!
I also stock a spade, PM me and we can meet up.
Tired of people hijacking threads, you speak about something and they want to sell you everything. Like prostitutes.
You clearly do not understand the question or cant read. Nobody asked for a Diesel Booster.
D
Dippies
Well i was reading Hiltons thread and he asked a similar Question and it got me thinking. He wanted to put two bottles in for better results on the Dyno.
I will wait for the expert opinions. but....NF Diesel boost makes your car run more efficiently, so is there perhaps a point where adding more does not gain you anything?
Executer
Inactive
+1
I think there`s a "cut off" where it will have negative results.
how often is more really more when it comes to engines? everything has an optimum level its just the way the physics works :)
1 bottle of NF Diesel boost is not recommended for less than 50l fuel...
the main functions of NF Diesel boost is:
adding lubrication to low sulfur fuel
cleaning fuel system and engine
adding cetane rating
I would suggest you do some reading on how cetane rating works to decide if your engine setup could benefit from more at all...
long trips would see benefit on the cleaning action provided you have run enough to let it clean...
real benefit of NF is under load when you pushing hard :) so not really long trips but short busts...
I sell the diesel boost at R 90 a bottle with free shipping on R 600 or more (you can order any products from Axis you dont have to spend the R 600 on NF alone)
well it takes time to clean one bottle will not really get much done but you will get the benefit of added cetane rating right away if your engine can make use of it...
S
S1NGH 001
Next time ODR are placing an order with you, I'll be sure to get some NF boost from you :rollsmile:
DieselFan
I've used liquidmollys Diesel Aditive, didnt notice any major differences. Where can i buy this in CT?
CliftonH
Hi. So how do we know which engines can make use of it. I got the E90 320d.
I was planning on throwing 2 bottles on a 3\4 tank tomorrow. Guess I shud not. Was gonna do it for kyalami this saturday hoping to give me more boost. I mean it says diesel boost right. Lol.
S
SP33DYV
Too much of a good thing, isn't always good, now is it? :) Follow the instructions on the bottle, they are there for a reason. The NF products are tested to be used according to the instructions on the bottle.
I suppose the car would cut "boost" completely if the Cetane content in the fuel are too high. :dunno:
CliftonH you ether need to experiment with different mixtures to see what works best for your car and conditions or do data logging to see where the engine can gain and mix according to that...
one bottle in 60-80l of fuel is a good starting point i would not just dump alot in and expect performance remember the car gets power from fuel... if there is no fuel in the mixture there is no fire... no fire means 0kw :) NF fuel additives alters how the fuel burns but is not fuel...
