N54 Troublesome parts.
Bonez0124
My (N54) 135i has just over a year left of motorplan, still on original coil packs & fuel pump. It had an issues the other day - warning light went on and car had a rough idle. At the time the car had Xcede SW
Pulled into a parking lot turned off the car, waiter about a minute before restarting and everything was fine. Car was flashed back to stock and went in for it's 2nd service and I asked them to check the warning light that came up. Initially they picked nothing up, I pushed for them to check again and they ended up replacing the injectors.
My question is I know the N54 X35i's had issues with injectors, HPFP's and a few other parts. Was there a recall in SA? Will I be able to get BMW to replace these parts under motorplan even if currently they are not faulty?
I put very few KM on my car, but would like the peace of mind that should I keep the car when the KM's are higher that the car will not have these issues.
As it stands, car is stock with 40K on the clock.
KrS24
You should be able to book the car at any BMW dealership for the recalls. You can contact BMW head office to confirm if you qualify for the recall.
bimmer330
Hi.
I took my car for the battery cable recall earlier this year. They told me that they have a recall for my injectors but will only replace if it causes problems.
