N54 Inlets Results
prmateus
Hey guys
I know i had a similar question and was wondering about the actual results gained by inlets not just ones posted by vendors
So here is my dyno graph done before and after only difference is the Inlets no other changes made.
My car runs map 6 running 19.5psi custom Down pipes and midpipes with Hartge back box, charge pipe and HKS BOV
As you can see my inlet setup isnt what you normally see as i we are RHD so I ran MMP style for the Front turbo and then followed OEM route for the rear as the stearing did not allow for MMP style, All of this was done DIY so no imported or expensive kits
If anyone needs help doing this in Gauteng let me know
prmateus
Karsh330d said:
Ah cool....And whats the cost of doing this?
The parts themselves arent expensive interms of piping and filters but there is alot of time involved so the labour costs are were it gets you to install
Acheron
I take it the Map 6 boost targets were adjusted between the dyno runs. i.e. after installing the inlets? Was fuel used constant between the two runs as well?
prmateus
No i ran the same map 6, didnt change because my Map 6 is pretty maxxed out without adding the new TMAP sensor for JB4 to read above 20psi
The gains are from the turbos being able to Hit the target sooner and stay there
Fueling was constant, it went for a dyno to the shop to do the inlets then back to the dyno nothing changed
Acheron
If the boost targets were consistent then that's a great result :clapper:
The reason I questioned fueling is that the "before" torque curve shows some evidence of timing pull where I'd normally expect it on an N54. Compare that to the "after" result, which is much smoother (unexpected considered the car is running more boost, sooner) I assumed that the fueling situation had been improved as well.
All in all, inlets are definitely a great mod on this platform whether it be to increase the upper limit of the stock turbos or simply to take some strain off the turbos when running 20psi or less.
prmateus
Yeah the problem was my map 6 was too aggressive originally for stock inlets in the logs you see the boost moving away from target quickly so I had lots of problems dipping into map 4
Saving up for fuel it now
prmateus
If you see the stock pipes you would be horrified at how bad they are
When i saw them i thought theyd flow about as much as an asthmatic through a straw
Acheron
Did you happen to log both runs? Would be interesting to see how PWM drops after the inlets are added.
Get that Fuel-it upgrade in there along with the uprated TMAP, run a decent mix of ethanol and you should be well into the 300kw range.
prmateus
Work life kept me busy the last few years took some time off recently and spent some time upgrading the car so I'm back now
