N54 coil packs
akash
Hi Gents
I'm in need of N54 coil packs, preferably brand new.
I have a misfire at WOT.
Any leads would be appreciated. Trying to get the car ready for the Rennzsport Dyno Day. If i cant get it sorted in time, i guess I'm just gonna be a spectator:cry::cry::cry:
fsalie
akash said:
Hi Gents
Akash ... sometimes misfire codes are generated by over fueling .... Do you run meth as well?
akash
fsalie said:
akash said:
Hi Gents
Yepp running meth, but the misfire happens before the meth can be activated.
The coils on my car is dated 2007/03.
I changed the plugs last month.
What i'll do though is drop the meth additive setting on the JB4 an see if that helps.
fsalie
akash said:
fsalie said:
akash said:
Hi Gents
Akash, not sure what your meth system is setup as. Mine is CM14 and I initially tried to get meth flowing at 14psi .... I lowered it to 8psi and never had any issues with misfires ... What you can also do is disable meth (default it should be on lower maps) and see if the misfire is gone. I have seen a lot of people getting misfires with meth being the culprit of overfueling/fouling the plugs
akash
I have the BMS kit with FSB controller and CM10 nozzlde, meth comes in at around 9psi.
But my meth additive is sitting at 65, im gonna dial it back to 50 (default) and see from there.
Boost on current setup is hitting 19.3psi
fsalie
If you in JHB or PTA I will gladly assist ... as said most of the time its the meth setup causing fouling of the plugs ...
akash
Thank you, Im in Midrand.
Come to think of it i never had a misfire on the car when the meth additive setting was at 50 or 40.
fsalie
I run a BT setup and has never replaced any coils. I even run OEM plugs.
I am in Menlyn, you most welcome anytime after 18h00 and I will assist. I presume your WOT runs are from 2500rpm?
akash
Yepp. Shyane and i have been trying to chase down this misfire, maybe we can all meet up and try to get my baby ready
Psypher13
Yeah
We can All Meetup
Fsalie is down the road from me buddy
Fsailie - def not meth
Setting should be good with that
The coils have been missing in 2,3 and 5
My assumption is if meth is issue it may be coil 5 predominantly
Akash scaling is low and comes in low as well - so wont be fuel
One thing i am not sure if we have tried Akash - did you run Map 2 so we can deduce if it is meth or not?
Kish2604
Administrator
Chaps, Stop messing around and replace the 6 coils, they are 07 dated so its there since forever...
its cheap enough from Diesel Electric....
Psypher13
200% Bru
That is what Akash will be doing.
:coolShake:
paulkane
akash said:
Hi Gents
I have a set. Not new but worked 100% Make me an offer. I also have injectors.
akash
paulkane said:
akash said:
Hi Gents
Thanks for the offer.
But I'm going to go for new coils.
