B1gw1ll said:Car looks great Enverh. Did you adjust your arches for the back wheels?
e46jase said:wow that looks sik! think the clear lights all round will make biggest dif loving the wheels on the black looks gr8 :thumbsup:
enverh said:B1gw1ll said:Car looks great Enverh. Did you adjust your arches for the back wheels?
hi
thanks, did not need to, they are 18 inch wheels and fit perfect even if i have passengers at the back.
B1gw1ll said:enverh said:B1gw1ll said:Car looks great Enverh. Did you adjust your arches for the back wheels?
hi
Ok cool, I have 19's on my 1 Series, and cannot have passengers at the back, so I need to either see where I can get a nice set of 18's or have my arches adjusted.
enverh said:hi
i got these from a guy in primrose , but later found out that Hi Q in bruma can also supply them , i am not sure if they can offer customised offsets but doubt it.
revo said:B1gw1ll said:enverh said:B1gw1ll said:Car looks great Enverh. Did you adjust your arches for the back wheels?
hi
or just get the right offset and widths in19s :thumbsup:
B1gw1ll said:Silly question, can you tell how to get the right offset?
scunick said:enverh said:hi
Thx... will give Hi Q a call.
scunick said:B1gw1ll said:Silly question, can you tell how to get the right offset?
Offset is the distance the hub is from the centre of the rim. For 1 Series have a look at 1addicts.com for tons of information on what fits. An example is this thread:
http://www.1addicts.com/forums/showthread.php?t=306109
There are some guys that will chop your wheel up and set up a custom offset for you, but beware this is not a cheap exercise. Better to buy wheels with the correct offset to start with.
Hope that helps and is not just teaching you to suck eggs.
Cheers
Nick
Just tried to get some sense out of the "uniquely bright" individuals at Hi-Q Bruma. All i got was..."ehh...sir... I can't hear you... I will call you back in 2 minutes... whats your number"....
That was an hour ago... idiots... oh well... back to the grind stone:hammerhead:
Later
Nick
B1gw1ll said:revo said:B1gw1ll said:enverh said:B1gw1ll said:Car looks great Enverh. Did you adjust your arches for the back wheels?
hi
