Gerhardm32
I have replaced the front brake pads on my '91 e34 535i on Saturday and found that there is a bush that keeps the caliper stable missing. See pic below. Will I be able to find this separate or not as the others are all fine.
On the left you will that the top bush is missing on the right hand caliper
Will need to do a proper bleeding of the brake system as the right side grabs harder than left.
This is the pads on the right side of the car, left had about 5mm of life left but also cracked
The disc doesn't have damage though
I also need those 2 seals under the brake fluid reservoir on the master cylinder, as per Bemow agents only
