cebbyp
Hi, I have recently experienced loss of power on my e38 (M62). Once the vehicle starts the revs remain low - under 2000 rpm, and do not pick up at all.
I since parked the vehicle and noticed the following:-
- Compression test was done and number 8 piston almost no compression
- Cam Box Cover was removed and one of the valves are loose. I used a screw driver and noticed that the valve underneath the cam follower is loose.
I need to know the following:-
- Whether the valve spring(s) might be broken
- Whether it might be a broken cam - follower
- Whether the valve is burned and need to be replaced.
I here wish to add that there has always been a silght misfire on the engine. I would further like to have more information on the process to be followed to correct the situation, I am familiar with engine overhauls, but the situation described herein gives me sleepless nights.
:bangdesk:
:bangdesk:
