Please advice problem with my 2007 e90 323i N52
Error shows air flow sensor
tried 2 sensors from other vehicles--vdo sensors,still showing air flow sensor
no readings on the computer for air flow
with air flow on and also removing it made no difference
wires tested ,all good according to Bmw mechanic
the only difference i see is the sensor on my car is VDO 5WK97502(mechanic put his one on) but according to real oem search it should be VDO 5WK97508
Will this make a difference as both can be used on e90 or should i be looking for the fault elsewhere
BMW OE PART NO 13627551638
