M135i Reviews roll in..
CocoPops
Its a winner! perhaps im lookin at my next car?
Autocar:
What is it?
A mix of dry and damp, tight bends and a narrow road should be challenge enough for a hot hatch with 316bhp to spill from its rear wheels. And if that sounds like a temptingly reckless number then you’d be right – it’s only 19bhp down on the output of the lately departed 1M Coupé, and the M135i’s 320lb ft of torque is identical.
If it comes with the optional eight-speed paddle shifter of our test car, the 135i will zoom-flick, zoom-flick, zoom-flick through the gears to 62mph in just 4.9sec. Go for the six-speed manual and the time actually rises to 5.1sec because its wider spread of ratios are less speedily swapped.
What is it like?
Either way, this new three-door 1-series is eagerly, muscularly and excitingly quick with the potential, you may think, to become a flailing handful if you dare to meddle with the ESP button. But the first bold dive into a rain-sheened bend uncovers grip reserves far deeper than expected – deep enough that when that DSC button is prodded for partial disengagement, it takes some lead-foot ambition to get the rear axle’s wider 245/35 R18s to get a skate on, the slide part-managed by a brake-deploying virtual limited slip diff.
So it’s pretty neat, controllable and reassuring, the more so because this rear-driver is quite a finely balanced tool, as proved by a too-fast arrival into a tight, low speed turn that fails to bring on any plough-on understeer. That said, you can expect to see plenty of the orange light that confirms an active ESP system, which is no surprise given all this energy and rear-wheel drive.
Perversely, it’s best to experience all this in the Comfort setting of the £515 Adaptive M Sport suspension, an essential option. It softens off the electronic dampers and lightens the steering effort to produce a satisfyingly communicative, more absorbent chassis and best of all, usefully more feelsome steering. Of course, tripping the Comfort mode slows the shift times and the gearbox’s willingness to hold a gear, but that’s easily undone by sliding the gearlever to leftwards to Sport, which gets you a more eager gearbox.
The result is a an excitingly rapid drive that sits just the right side of hectic, the excitement of the six’s keen blare built on by the ‘box’s light thumps in sport, the ra-ta-tat of the exhaust’s over-run, the lightly clasping support of the seats and an excellent driving position. While some may desire the more uncompromising character of the 1M Coupé, the fact is that this M135i’s ride is less maskingly firm, its steering more delicate and its character easier to live with. And it’s also a whole lot cheaper, being almost £10k less.
Of course, you do without the some of the 1M’s alloy suspension hardware and massive brake rotors – although the 135i’s enlarged blue-calipered discs are entirely effective – but remember that the M135i rides on the latest 1-series platform besides benefiting from bespoke suspension geometry and its own springs, dampers, anti-roll bars and bushes.
More immediately noticeable M135i identifiers include a new front bumper unit with larger air intakes, a rear bumper with twin exhausts and 18in alloys, and tyres, that are wider at the rear. Inside you get leather sports seats (the UK won’t be getting the appealing Alcantara/hexagon cloth mix of the test car, which seems a pity), a black headlining, an M footrest, blue accent stitching to the seats, patterned aluminium trim inserts and modified instrument faces. Not a huge amount of differentiation then, but enough to mark this 1 out as something sportier. The cabin is robustly constructed too, although it’s not as finely, designed, finished or textured as the cabin of the latest Audi A3.
Much of the M135is’s considerable entertainment repertoire is provided by the straight six. This Twinpower motor features a twin-scroll variable geometry turbocharger, variable timing of both inlet and exhaust cams, variable valve lift and direct injection, these features managing to almost eliminate turbo lag. Indeed, you must actively search it out to find any, by shifting manually and having the revs build from 1000rpm to the 7500rom limit in second, say. Then you’ll uncover a slower-moving tacho needle to 1300rpm. From this point the six has already reached its 320lb ft torque peak, this figure impressively maintained through to 4500rpm, although the revs don’t rush at you until this peak has passed, the tacho needle performing a lightning flit to the limiter.
Throttle response is not as instant as you’ll find in a normally aspirated M3, but it’s sharp enough for most circumstances. Couple the six’s breadth of urge to that eight-speeder, and you have a car that powers near seamlessly from a dawdle to its easily struck – and restricted - 155mph maximum.
M division has tuned the 135i’s exhaust to provide a smoothly busy soundtrack that makes paddling your way through eight ratios an absorbing business, even if the noise can turn slightly wearing. Happily it quietens off at a motorway cruise. And we suspect the same may be true of the ride, which showed signs of choppiness on Germany’s mostly smooth roads.
Should I buy one?
None of this seriously diminishes the appeal of this car, which has to be one of the most entertaining in the entire BMW range, offers truly memorable go for the money and a highly capable and entertaining chassis besides. It’s a shame that the 1-series, three-door or not, doesn’t make a more appealing eyeful, like a Vauxhall Astra GTC. Maybe the next-gen 1-series coupé will fix that.
http://www.autocar.co.uk/car-review/bmw/1-series/first-drives/first-drive-review-bmw-m135i
Auto Express:
The BMW M135i is a hot hatch version of the new 1 Series that makes even the 276bhp Vauxhall Astra VXR seem puny. It’s also the first petrol model from BMW’s new M Performance sub-brand, and the first three-door version of the new 1 Series we’ve had the chance to test.
With 316bhp from its 3.0-litre turbocharged engine, and a 0-62mph time of 4.9 seconds, it can outstrip a Porsche Cayman R in a straight line, but promises more everyday usability than the extreme 1 Series M Coupe. “The M Coupe was a race car that had been tamed slightly, whereas the M135i takes the road car as a starting point and takes it to the limit,” Dr Friedrich Nitschke, BMW’s M boss, told us.
Under the skin, this is a very different car to the M Coupe. Firstly the six-cylinder engine has a single, rather than twin turbos, there’s no limited slip differential, it uses adaptive dampers instead of rock-hard fixed-rate suspension and the M135i comes with the option of an eight-speed auto, unlike the manual-only M Coupe.
But don’t imagine for a second this car is soft. The engine’s performance in thrilling, although it never feels too ballistic for the road, and it sounds fantastic too – the raspy engine note fills the car and there’s muffled pops and bangs from the exhaust on the overrun.
What sets this sensational powertrain apart though is its smoothness, even as you scream towards the 7,200rpm redline, which is partly thanks to the superb eight-speed auto gearbox. The six-speed manual will still be the purists choice, but there’s now no shame in ordering the auto.
The standard M Sport adaptive suspension sits 10mm lower to the road, but leave it in Comfort mode and it’s easily forgiving enough for everyday use. Crank it up through the driving modes though - which also tweak throttle response, gear change speed and steering weight – and it gets significantly firmer. Sport+ is best reserved for driving on track, but even so it’s not as bone-shaking as the M Coupe.
Our only gripe was with the variable-ratio steering, which is sharp and accurate but too light for a car this fast. Hit a bump mid-corner causes the wheel to wriggle in your hands, which can upsets the car’s balance. That aside the grip levels are impressive, throttle response is immediate and when you want to act like a hooligan turning the traction control off in the rear-wheel drive M135i is far more fun than with the four-wheel drive Audi RS3 or forthcoming Mercedes A45 AMG.
If you plan to use your M135i as a family car, a five-door version will also be available from September, although 75 per cent of buyers are expected to take the three-door. And if you can bear clambering over the front seats to get into the back, it’s easy to see why – it looks fantastic with deeper side-scallops, 18-inch alloys, M Sport bodykit and that hallowed ‘M’ badge on the boot.
Read more: http://www.autoexpress.co.uk/carreviews/firstdrives/285676/bmw_m135i.html#ixzz1zqrh9aYN
BMW Power.
J
Josh-ZN
this car is growing on me. i would prefer a coupe version but this car is looking good
Zack
cocopops said:
3 Door Base Price: R445 500
5 Door Base Price: R453 000
aren't the 3 doors usually more expensive than the 5 doors? :thinking:
But that seems like a fantastic car. Shape is something to get used to though
