Quick///M
Hi Guys
Fan kicked in really loud this morning on different 2 trip. The car rested for 30 minutes between the trips. I knew something is up so i read the codes on the ECU with torque pro and it popped up with P013A Power train fault (P013A Generic DTC: O2 Sensor Slow Response - Rich to Lean)
There car is on reserve tank, I am not sure if this could cause a lean condition in and effort to save fuel, also the 1st trip when the fan kicked and it went into limp mode I was in ECO Pro on highway
I cleared the error with torque pro will see if it appears again. Has any had this issue or similar ?
