Low power on pullaway
Peter Henning
I have a 2004 E46 318i with the intermittent problem when there is very little power on pullaway. I read lots of queries on this, a fellow worker has exactly the same problem. Never seems to be any answers. Has anyone solved this problem successfully?
andrewbuch
Could be the MAF (airflow meter) needs replacing
does the power fluctuate? Like has no power then suddenly surge of power then again nothing?
Try unplugging the MAF & see if its the same?
When I replaced my MAF I Also put in new plugs as they needed replacement anyway.. after that I could really feel the difference
xcalibur
I had this on my ST until I started "servicing" the MAF and MAP sensors. This seems to be something they do not do with a service.
I clean them every +/- 5000kms with some IPA (Isopropyl Alcohol AKA Running Alcohol). This needs to be done very carefully though as there are very thin sensor wires you need to be careful about not breaking.
Diablo Jnr
List of things to check
1) MAF
2) Resonator box (remove it and checks for holes)
3) Check you spark plugs (if you have oil on them, replace your tappet cover gasket)
4) Clutch
good luck with this x-file dude
Peter Henning
Coisman said:
:pimp:
Peter, jou pa is nie dalk Louis henning nie??
Hi, nee pa is nie Louis Henning nie
Problem is frustrating me terribly - spoke to the local BMW dealer today who mentioned numerous possibilities. Have decided to book the car in for them to diagnose. Will report back after the visit on 05 April. Also got the impression they have attended to many similar cases.
