SirSparky///M5 said:
i got a qoute from diesel electric on universal ones....you have to use your own plug for R700 each...and they are the 4 wire ones
other than the longer cable....are the front ends the same though?
Aaahhh yes...I got the same quote from diesel electric, but have not driven through to pick them up. The Bosch universal ones do look very good, and require no weird cable matching or anything...its just same colour to colour which is great. Heard good things about them on the net...
I believe that they come with 600mm of cable on them and you can cut them down to the size you want. The front ones are 320mm and the rear are 580mm.
Yes, one side of the exhaust is a mirror for the other. The 2 front are identical and so are the back...
If you go with them, please report back on how they work because I need to pick up a few for my 7
