issue with creating a wifi setup with router
wolfman7
Hi guys, hopefully someone can assist.
my issue is i have a fibre connection at home, and i have been using the normal adsl/broadband cable to connect to the internet, via the port on the PC (forgive my misuse of terms, i know nothing in this field).
now i received an Ipad mini (wifi only) as a gift, so i bought a router, hoping to create a wifi connections via this port in the wall.
i manage to setup some kind of connection via the laptop, (don't know how i did this), so the laptop can connect wirelessly now. but i can't connect using the Ipad. the ipad picks up the router, and when i click on the connection, it prompts for a password which i enter and then it shows a blue tick, but i can't browse the net.
someone please expand my knowledge on this
Quick///M
What router ?
Could be dhcp thats not dishing out dns, or mac filtering, or a host of things.
Post pics of your cabling
Nick
Some things to try first:
1. Turn Off your iPad. Then turn Off (disconnect power cord for 30 seconds or longer) the wireless router & then back On. Now boot your iPad. Hopefully it will see the WiFi.
2. Go to Settings>Wi-Fi and turn Off. Then while at Settings>Wi-Fi, turn back On and chose a Network.
3. Change the channel on your wireless router (Auto or Channel 6 is best). Instructions at http://macintoshhowto.com/advanced/how-to-get-a-good-range-on-your-wireless-netw ork.html
4. Go into your router security settings and change from WEP to WPA with AES.
5. Renew IP Address: (especially if you are drooping internet connection)
• Launch Settings app
• Tap on Wi-Fi
• Tap on the blue arrow of the Wi-Fi network that you connect to from the list
• In the window that opens, tap on the Renew Lease button.
Source https://discussions.apple.com/thread/5951318
wolfman7
will give all this a try when i get home tonight.
Quick///M said:
What router ?
Its a Hauwei HG532 or something, not at home now bud, will take a pic tonight. but its the normal broadband cable that you get at incredible connection or so. it has that big copper head.
Shiny
It doesnt sound like a problem getting an IP address. I think you need to check that the WiFi and etherner ports are bridged and allow traffic through.
Can your fibre router not have Wifi built in?
wolfman7
i think the problem is the router is for ADSL, i need to get a router for broadband.
i'm selling the ipad, don't really need it. should have decided this before i opened the packaging
MikeR
if its wireless - it will work, just need to sort the setting, if it works on the laptop, then the settings are with the iPad.
