Imola395
Hi all, trust everyone is well.
So I've run into a very strange issue on my E82, I will try explain as detailed as possible.
The weirdness started 3 weeks back. We had hail warnings when at work and I ran to move my car under cover. Unlocked, jumped in key in slot and tried starting it like I have done a thousand times.....Nothing! Pressed the button repeatedly, nothing. The icon never came up to say hold brake/press clutch to start so it registered everything normal. I sat for about 10 minutes trying and out of the blue it starts again like nothing happened!! Never had that issue again or any other issue....
Then last week, my indicators started acting weird.
When using indicators normally, they flash fast like one of the bulbs are fused. So I put hazards on to walk around the car and see which one it is, just to find they flash normal! All globes are fine and working. I have had an issue for a while where I get warnings that lights are out but everything still works.
Now for the fun one!
I cant get my ignition on or my steering locked! I insert FOB into slot and the gauges jump a bit, so it wakes up the DME! But there is nothing else that happens, slot doesn't grab key, steering doesn't unlock and ignition does not come on! I have swapped out key reader, CAS and FRM into my wife's car and it all works like normal. I have bridged pin 1 & 16 on OBD to open the BUS to be able to read modules. I reset ALL modules and cleared faults and still nothing.
I have had someone say its the steering column, but I cant see it being that. It never gave me any warnings and even when its completely shot, it will give the warning in red. Not just be completely dead. I did reset the ELV as well but its all still dead. I have checked every single fuse and relay behind cubby (never again!!) and they are all in the correct spot and not blown.
Does anyone have ANY idea what I can check for from here? I've been checking and testing three days now and I have exhausted my knowledge of BMW!
Thank you in advance!
Leon
Leon
