Hi,
So my e90 320d has started doing the whine thing when cold. When warm, the whine is still there but just less audible. The whine is constant under idle, increases pitch with higher revs, then lazily drops down when releasing the pedal.
The whine seems independent from the turbo whistle (which those of you with good ears will probably hear alongside the whine in the clip).
uploaded audio clip here: .
It was recorded with a phone so the volume is not apparent in the clip but to my ears, it is incredibly loud.
If it helps, when the air conditioner is switched on, there is an extra rumble from the engine bay that does not go away when the car is warmed up.
I will probably take it to the dealer but this is my primary means of transport and all of the dealers I've dealt with have had issues with supplying courtesy cars.
