Is there a demand for diff ratios?
2sly4u
Hi guys
I'm just curious. Is there a demand for diff ratios? If so, which ratios would you guys be interested in?
2sly4u
ChrisBrand said:
3.46 or 3.38
Small unit? I have a 3.46 in a small unit
Kish2604 said:
LSD solutions for e46 and e90 please...
Only options are to fit an E46 M3 suspension into the E46 and a E90/2 M3 suspension into the E90. Else there's a place in Durbs who does LSD conversions for around 16k. Transaxle Gearbox and Diff. 031 705 4517
ChrisBrand
Staff - Legal
2sly4u said:
ChrisBrand said:
3.46 or 3.38
Out of which car did the 3.46 come?
2sly4u
ChrisBrand said:
2sly4u said:
ChrisBrand said:
3.46 or 3.38
E46 325 Auto
Nikhil
2sly4u said:
ChrisBrand said:
2sly4u said:
ChrisBrand said:
3.46 or 3.38
E36 325
E36 325i is 3,15 ratio
ChrisBrand
Staff - Legal
I think it should fit my car. Let me just make sure and i will let you know. Not sure if the e46 328i has a "small unit" diff.
2sly4u
If you have an E46 328i then it will fit. It is only the E46 M3 and the E36 4-Door M3 that has the big unit. But you're welcome to do further analysis :thumbs:
ChrisBrand
Staff - Legal
You have pm
2sly4u
4PipeR said:
Yup 3.91 for e46 M3
I'm looking out for the 3.91. 2 guys asked me already. As soon as I get 3.91's then I will post it, however I will let those guys know. If not I will contact you.
2sly4u
CliftonH said:
Just a question to us guys who don't know about diff,
What options would there be for e90 320 diesel,
A diff ratio can either increase or decrease your rpm. The examples below are for petrol cars
Example 1: A 4.11 diff ratio
- This allows you to accelerate quick through your gears
- RPM in 5th gear at 120km/h would be on 3300rpm
- Top speed 215km/h
- These diff ratios are not ideal for fuel economy
Example 2: A 3.15 diff ratio
- This allows a drag in every gear, very sluggish
- RPM in 5th gear st 120km/h would be on 2300rpm
- Top speed 250km/h +. The guys who builds top-end BMW M3's usually use a 3.15 or a 2.98 ratio which allows them to run speeds of 320km+
The ideal ratio which one will go for is a 3.64. The ratios are as follows:
2.98, 315 - Very long
3.46, 364, 3.72 - The in between ratio, depending on your car and Mods
3.91, 4.11- Quick acceleration through gears
4.44 - Extremely quick acceleration through gears
I hope this helps
netercol
e90 320d has a 2.56 diff ratio , top speed in top gear around 227km/h, max torque 1900-2700 rpm
a 4.11 diff in a e90 diesel manual would give a topspeed of around 150km/h
a 3.15 diff in a e90 diesel manual would give a topspeed of around 180km/h
