Is an increase in fuel consumption a symptom?
Caddy101
Hi guys
Recently I've notices an increase in my fuel consumption. I used to average about 9.7 l/100km. Now I'm up to 11.2 l/100km.
Driving style hasn't changed, the only thing that has changed is the weather (winter temperatures). Also I don't live very far from work, about 4 km.
Could the increase in fuel consumption be a symptom of something going wrong?
The car in question is a 2006 323i Exclusive, with 115 xxx km on the clock.
:thumbs:
Whacko
It might be a symptom of a heavy foot. :rollsmile:
On a serious note, if there is more traffic, your consumption will go up.
P1000
Makes sense, the engine takes much longer to warm up. Warm-up enrichment adds a LOT of fuel - in some cases up to 100%
It will not be so severe if your commute was longer and the engine spent a bigger percentage of its time already warmed up. There is nothing you can do, just be happy that you only need to commute 4km.
AshG108
Caddy101 said:
aZZ_kIkR said:
when my consumption went up, it was because the VVT Motor was on its way out...
What other symptoms did you have?
- consumption went up
- car was down on power, was a dud
- was a bit rough on idle(not a lot but you could hear it more rowdy)
Caddy101
Will have the codes read. This will show up on a diagnostic, right?
Raybimmer
interesting , I notice my cold start consumption is heavier than when warm , so temperature must play a role .
