INPA Question
GPGrobler
Does this connect to the E46, can I read all the error codes using it?
Once again, thanks in advance. :thumbs:
S1NGH 911
Yep cable works on all BMW's using the OBD2 port till late 2008 (I stand to be corrected).....
INPA itself will be able to read and clear codes on the E46 ....
S1NGH 911
I'm not sure about that, but if you referring to coding stuff like the alarm beep etc, you're gonna need NCS expert for that......
Sent from a tikkie box using Tapatalk
GPGrobler
Chris Brand gave me a link to a pricier unit, but you have to know what you are doing, otherwise you'll end up de-programming the car! :bangdesk:
