iK Sprayers now available through G Shift
gavsadler
Hello all,
G Shift is pleased to announce that we are now able to offer a range of IK Multi-Purpose and Foam Compression Sprayers to the Enthusiast.
By experts for experts.
For over 60 years, the Goizper Group has been designing and manufacturing high quality sprayers for the Automotive, Industrial, Janitorial, and Construction sectors from their state-of-the-art European facilities, developing a reputation as a true leader in the industry.
IK professional sprayers are characterized by their manufacture with high quality materials and by their design, conceived by professionals for professionals.
The protection of our users is a priority for IK Sprayers. Our sprayers are equipped with safety systems such as: pressure relief valves, automatic air release systems in case of accidental opening, locking of operating handles and UV-resistant materials. Preventing accidents and misapplications is also part of our philosophy, which is why the identification of the chemicals to be sprayed is crucial and that is why we equip our sprayers with colour identification systems.
In order to work quickly and efficiently, the ergonomics of the sprayer play an important role, which is why every product we put on the market has undergone an exhaustive ergonomic design study.
There is a sprayer for each type of work, find the one that best suits your needs.
Some of the more popular IK sprayers are now listed on the G Shift Online Store here: iK Sprayers
Stock is available locally for most sprayers. For those not in stock, it will not be an issue to bring them in to suit your specific requirements.
Some videos and pictures added below.
Also note that these are quality pieces of kit, so they are priced above other similar products which may be available in the market.
Current pricing (*also sensitive to exchange rate fluctuations) as at Feb-2021 is as follows:
  • iK Multi Pro 2: R767
  • iK Multi Pro 9: R2274
  • iK Foam Pro 2: R857
  • iK Multi TR 1: R441
  • iK Foam 9: R2373
TurboLlew
Foam Pro 2 incoming!
Pricing is good. From Amazon it would have cost around R1000 (whether shipped by them or AGS).
Great stuff Gav! Store is evolving nicely!
gavsadler
Bump to the top.
New stock has arrived in South Africa, and the online store is updated with stock available and pricing.
  • Foam Pro 2: R921
  • Foam Pro 12: R3045
  • Multi-Pro 2: R773
  • Multi-Pro 9: R2373
  • Multi-Pro 12: R2462
  • Multi TR1 Trigger: R442
  • HC TR1 Trigger: R489
While stocks last. Contact G Shift for more details.
gavsadler
New Product Launch,
The popular Foam Pro 2 has been enhanced. Enter the iK Foam Pro 2+...
From iK's website:
The IK FOAM Pro 2 + handheld sprayer is a foam generator designed for cleaning tasks in various sectors.
Foam Pro 2 + can be actioned two different ways: manually or with the compressed air connector. This valve is widely used in the field of pressurized tires. It enables the tank to be pressurized by means of generic compressor modules such as those intended for tire inflation. The air connector makes the pressurization process faster and easier by using widely commercially available devices with no need of manually pumping it.
This sprayer has a wide filling mouth, ergonomic design, safety valve set at 3 bar (depressurisable), base for greater stability, coloured caps to identify the contents of the tank, safety lock on the opening and closing system.
It is equipped with three mixers (orange, grey and green) which allow to vary the type of foam by choosing between wet, intermediate or dry foam.
With the use of the foam we manage to increase the contact time between the chemical and the surface to be cleaned, cleaning fabrics and upholstery avoiding excessive soaking which generates the appearance of fungus and bacteria, and finally having greater visual control of the sprayed surface.
The easy manual assembly and disassembly of the IK Foam Pro 2 +, allows a complete maintenance without the use of tools
