Horn issues
GHOST E90
Hi guys...
So i have searched the forums with no luck so hoping some one with here can share some info...
My horn stopped working but when the horn is pressed you hear the relay in the cubby ticking.
So i started by searching the forums and seems to be a commonly reported fault but nobody reports back on how they sorted the problem.
So i started by checking fuses. Guys feel free to correct me if im wrong along the way... so horn fuses on the e90 is listed as fuses 16 & 59.. the fuse in position was burnt out so i replaced it and the horn is working again, but now it seems to be way softer that what it originally was...in fact my horn sounds a bit sick now, im actually embarrassed to press the horn now :nonono:
Any light shared on this topic would be highly appreciated .Thanks guys :thumbs:
Iceman007
GHOST E90 said:
Hi guys...
replace the Horn. I think its located in the front part of the wheel well if you loosen the fender liners you should see it
http://www.e90post.com/forums/showthread.php?t=589953
