Hi Guys, new to forum
jeff_denning
Welcome to the forums! Hope the car hasn't been overheating regularly? With E39's it's a fairly common issue though, you'll be best off replacing some parts:
  • Thermostat
  • Radiator Hosing
  • Head Gasket
  • Coolant flush
The same thing happened to my 525i last year sometime, the dealers set me back around R7k including a pressure test to make sure the head wasn't cracked. If you tell us where you based someone can recommend a workshop you can take the car to :)
525TOURING
  • Thermostat
  • Radiator Hosing
  • Head Gasket
  • Coolant flush
Im in jhb, had some backyard cowboy work on it, set me back more than dealers and just about destroyed my car
Still figuring out the forum, im in jhb, to make a long story short; had some backyard cowboy just about destroy me engine.
Raybimmer
Welcome to the forum . Search for Gizmo on the forum . He ( Warren du Plessis ) should be able to do the job , good service .
If you battle post again and I can give you his number .
