Help reading codes in the Midrand area
akash
Hi Gents
I’m in need of someone that can assist with reading codes on my wifes e90 323i.
The car is not drivable, it had its tappet cover gasket recently replaced, but now has a very bad idle.
Phyper13 usually helps me out but he’s away on work. If anyone in the Midrand area can assist that would be great.
Thank you
akash
jerzi said:
Did you check the coil packs?
I check the coils and they are all secure
DannyBoyOPC said:
I might be able to help you, however it would only be on the weekend.
Thanks For the offer.
But i'll be in Drakensburg from Friday
jerzi
Remove one coil at a time while the car is running you should hear a drop in revs, if you do not hear one it could be a shot coil, swap the shot coil with a working one and try again maybe just a coil.
If you have a N46 motor, coils are very common?
akash
So I'm, leaning towards either a Solenoid, Valvetronic motor or the Eccentric sensor.
But reading the codes would be my best first step.
jerzi
PM me will give you a contact he has launch not sure if he is available and will come out to you though. He has a work shop in isando.
good luck
Danny2
My apologies, ill see if i can make a plan for tomorrow night or even thursday.
PM me ur details and ill make a plan
akash
Thanks Bro
Pm Sent
akash
Update
So Phypher13 came over today to help read the codes. Turned out to be the outlet vanos solenoid. We pulled both solenoids and gave them a clean. Fitted them back in, cleared the codes. First time startup no issues. I drove the car to gym and back home, no problem.
Thanks to my brother Shyane for coming to the rescue.
Thank you to DannyBoyOpc for also offering assistance while Shyane was away.
Danny2
akash said:
Update
No worries bud, glad u came right
