Help, N47 vibration with fault code 24BF00
vjx
Hi guys,
I need your help.
My 520d with N47 engine starts random vibration when stops at traffic light, but it drives well no sign of power loss. Mileage: around 95000km.
I checked DDE. It shows 24BF00 error only:
Zero-quantity adaptation, injector cylinder 2: permissible filtered activation duration correction too high.
Anyone having same issue? What's the cure?
Thanks in advance.
Danny2
if you want to bring the car around i will scan it with ISTA for you..
I suspect your injector might be the problem or even wiring to the injector
Nikhil
vjx said:
I don't see any extraordinary smoke from exhaust.
95000km with broken injector? :rage:
Yep also thinking injector issue. Injector life has largely to do with fuel quality
vjx
Here I would like to thank Danny@DSCMotorsport for installation and coding the N47 20d injector.:ty:
And @Opperman for organising me BMW OE Injector.:ty:
