hi Guys,
I'm new to the forum. There is an E90 320i that i would like to buy, but im not convinced of its service history.
I called up BMW and they gave me a Motorplan CIA print out.
The car is currently on 122 000km
The print out goes as following:
8 000 - Replace globes
28 000 - Standard Scope CBS, oil change
42 000 - rear brakes
48 000 - Standard Scope CBS, Vehicle check CBS
58 000 - Standard Scope CBS, oil change, brake fluid flush
71 000 - Standard Scope CBS, brake fluid flush
84 000 - Wheel bearing front + wheel bearing rear
End of print out.
The current owner has the car since 115 000 and he has a invoice for the last service, done at 120 000 km.
120 000 - Service vehicle check. Service standard scope
Brake pad, brake disk front, brake sensor
Starter/Stop replace
The OBC shows the following:
Service - 50 000 05/2015
Oil - 8000 11/2012
Front brake - 60 000
Rear brake - 4700
Brake Fluid - 10/2011
This history shows that the last oil change was at 58 000km. Does this history seem right. Is there a service i am missing here? Did the owner skip a service and reset the Service Info OBC?
End of print out.
Oil - 8000 11/2012
Rear brake - 4700
