Hedgehog resistor
plonkster
I replaced the final stage driver this morning. Reason: The blower fan will turn off after 10 to 15 minutes. The only way to stop it from doing this is to put it on the fastest setting when you start the car. Obviously the unit heats up and stops working, but a higher setting (ie less resistance) means less heat. More on this later.
Some thoughts, notes, advice follows.
First, you can find a very nice howto here: http://www.motormec.co.uk/aircon.pdf
Some advice and details:
On the 320d e46 there are a few differences. The OBD2 plug is there, but the warning buzzer and footwell light isn't. Less wires to disconnect.
The so called sharp metal clips really just clicks into place, as long as you work carefully there isn't any real danger of damage.
The ventilation pipe down there got in the way the whole time, but you can work around it. Having a head mounted flashlight might help, but I didn't have one.
Some people (on other forums) had trouble with their T-20 driver being too long. I have one of these socket-set kits with a 1/4 inch ratchet and connectors so you can use the torx bits with the ratchet and an extension. This worked really well.
Pull fuses 28 and 50 while working on this. Keep the unit plugged in while pulling it from its mounting point, the plug gives you better grip. I didn't do this and used long-nosed pliers instead, and it was a real pain to get it out of there. BMW has helpfully over-engineered the fitting (two screws and two plastic clips) while under-engineering the part itself causing it to fail every couple years.
When I finally got the old part out, I saw it was manufactured in the 29th week of 2005 (ie it has already been replaced once before, also indicated by screwdriver scratch marks and a missing screw), and the part number differed slightly. That means BMW changed the part again since 2005, and the old one lasted 3 to 4 years. Hopefully the new one will last longer. Then again, I might just sell the car before then.
Some thoughts on that. It seems the final stage resistor unit is more than just resistors. Looks like all the parts that generate some heat was mounted in this package, and it consists of a couple resistors and transistors. From my limited analogue electronics knowledge (ie not switch mode), the slower you want the fan to go, the more heat is dissipated in the transistor/resistor setup. In other words, this unit relies on airflow to cool it down, but when there is the least airflow, this unit generates the most heat. One would hope that the engineers factored that into the design, but I suspect this is a case of an initial design flaw, which led to the mounting space being made just that big, which now means you have to make the replacements just that big... the obvious improvement where the "hedgehog" now have more prongs has already happened.
In addition, it seems this part is also used in the X3, the X5, some M5's, Rovers, Land Rovers and Range Rovers.
I'd be interested to hear of similar experiences and/or thoughts.
freerider
Sweet, the 540i also needs a new one of these, fan is either on "freeze my nipples off" or "Melt that sucker"
cdr693x
I have the same problem on a E39. Anyone know of a good source in Gauteng?. Maybe cheaper than OEM.
freerider
I got quotes from 2nd hand places and BMW....
Scrap yard R600 no guarantee on electrical parts
BMW R608 + VAT and its brand new.... no guesses which one I would pick.
plonkster
R608!!!? Where? I got mine from Forsdicks at R1205 (vat inclusive). I knew it was more expensive that it had to be but not by this much. Based on the knowledge that a ECT-switch (engine coolant temperature) on a Corolla is R650 at the agents, this seemed in-line with the usual "rook-die-klient" practices.
I actually did the mental math at the time. I knew I could get one off ebay.co.uk at 41 pounds, 5 pounds shipping and some duties once it gets here, probably round R800 or so, then figured R400 extra, though a lot, is not too much to just get the damn thing right now...
Heres one even cheaper at 34 pounds. Also, rand is particularly strong right now...
http://cgi.ebay.co.uk/BMW-HEATER-BL...temQQimsxZ20090904?IMSfp=TL090904203002r23874
freerider
The quote I got was from SMG Canal Walk, that was for the e34 540 HVAC final stage resistor.
mohy
Hi
If you are still interested I can get you a brand new one for R700.00 please advise me of the old ones part number.
The units are available in Gauteng
semaj
When BMW quoted me last year for one of these they were about R1100 so I decided to wait until it completely packs up. I'm planning to get mine on Ebay for $50(+-R380) incl shipping. You'd be unlucky if you have to pay VAT and customs duty, I've never had to pay on goods worth less than R500.
