Hi All technical minded BMW Fanatics!:wave:
I need some help today please - :thinking:
I own a 1994, 316I manual (E36 dolphin) that is still in good condition and which I enjoy driving a lot. It has done 159k kilometers on the odo and it is about 6000 km since an engine overhaul. The car goes well, is a bit heavy on fuel consumption (app. 8km/l tame city driving).
However, the heat dial now started showing symptoms of dysfunction as follows:
It work normal at start-up and reach the 'normal' temperature position soon (as I am used to it). After about 15Km or 15 minutes drive the needle simply drop right down to bottom of the 'cold' position where it stays. When I stop the car the gauge may pick up slowly but drop again when you start driving.
Is this an indication of a 'bigger' problem or perhaps electronic in nature - a sensor (??)
Any comments and advice re the above is much appreciated.
Also (on a limited budget), what could I expect to pay to have this fixed?
I live in New Germany (Pinetown, Durban).
Thank so much in advance for your assistance!
Cheers,
J
Cheers,
J
