dineshcooper said:
Hi,
I replaced my headlamps on an E90 320D a month ago and noticed today that both have blown again. Interestingly the lamp error symbol did not come up this time though!
The bulbs I used were the Osram Nightbreakers and I was very careful not to touch the bulbs at all when I replaced them.
Any ideas on what could cause them to blow so quickly?
And why would the lamp error symbol not show?
not specific to your problem or the quality of the Osram Nightbreakers but
1) A globe that is On is less brittle and thus doesn't break due to impact or vibration, compared to a globe that is off and subjected to vibrations and shock motions
2) Touching the glass only affects the unifrom temperature over the entire surface of the glass, due to oil deposits heating up and creating localized hot spots on the glass, this can in turn affect the cooling or operating temperature of the fillament inside,
3) Incorrect voltage or faulty voltage regulator could cause excessive current being fed to the globes
so based on the above
1) do you drive with the lights on....making the fillament less brittle and thus able to absorb road vibrations/shocks etc
2) if you drive mainly with the lights off and/or on uneven roads, then also factor into account if the fitting is secure, or does the globe have free-play, thus allowing it to recieve extra unnecessary shocks and vibration
3) always driving with the lights on will unfortunately also cause the globes to burn out faster mainly due to useage, but it should last longer than your current time period.
4) Touching/not touching the glass during replacement is only a casual factor for possible localized hot-spots on the glass, which can increase the operating temperature and thus reduce the lifespan.
5) The fact that your warning display doesn't indicate the blown globes makes me wonder about either a computor fault caused possibly due to a too-high/faulty voltage regulator which is also passing thru a too high voltage to the globes causing them to blow....or you have an earthing/short circuit problem on the globe mountings, which could also be the problem either to the globes and/or the computor warning function
