+1ASH M said:-If your amp has HDMI inputs then use them to connect the PVR and PS3 and have the output HDMI from the amp going into your tv. This way you will have sound from the amp and TV if needed.
Caddy101 said:+1ASH M said:-If your amp has HDMI inputs then use them to connect the PVR and PS3 and have the output HDMI from the amp going into your tv. This way you will have sound from the amp and TV if needed.
:thumbs:
If your amp has a video output, then connect all the inputs to the amp and the video out from the amp to the TV.
My system is connected this way.
Naruto said:Thanks guys.
Will definately try some of the things tonight![]()
Do you have PVR?Smartiesman said:Naruto said:Thanks guys.
I got mine as so.
PS3 HDMI to TV and audio cables to amp
works fine.
Naruto said:Do you have PVR?Smartiesman said:Naruto said:Thanks guys.
I got mine as so.
works fine.
This might be key!ASH M said:-If your amp has HDMI inputs then use them to connect the PVR and PS3 and have the output HDMI from the amp going into your tv. This way you will have sound from the amp and TV if needed.
-If your amp doesn't support HDMI then connect a fibre optic cable from your PS3 to the amp. When doing this you can set the PS3 to use multiple audio outputs, which in turn allows you to still use the audio from the TV if you don't want very loud sound while playing/watching on the PS3.
-If your amp doesn't accept fibre optic then you can connect av cable into the amp then have the amps output going into the TV for video. If your amp doesn't have its own video output then leave the PS3 connected like how you described and then connect the audio output from your TV to the amp.
Now if you don't come right with this go outside and cry
Just kidding, good luck:roflol:
Naruto said:TV has one HDMI slot. I have connected the HDMI cable from the PVR to the TV and connected the AV cables in the PS3.
I have the AV cables from the PVR to the AMP....
Now all I want is to have the SOUND coming out the the Surround(AMP).
Was thinking of connecting the HDMI cable into the PS + AMP. Would this work?
Will try it tonight
